EdleBrock headers
Old Feb 4, 2007 | 03:01 PM
SuperZ's Avatar
Default EdleBrock headers
You guys using the edlebrock stepped headers with the 3.5 collectors.How do you guys like them?Did they go in easy like a pacesetter would???Any info would be great thanx!
Old Feb 4, 2007 | 03:04 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I had to grind the tab on dr. side a little..that was it..nicely coated, don't hang low, and nice welds with no slag or burrs in them to clean up....
Old Feb 4, 2007 | 03:08 PM
Asmodeus's Avatar
Mine went in like they were meant to be there. They seem to do pretty well. I went with the race style so I'll always have a little bit of an exhaust leak at the collectors. I can live with it. A 3.5" band clamp with a little aluminum foil between the two really helps. Only time I notice it is a kind of rattle if I let the car coast down from 4500+ rpm's with the clutch in.
Old Feb 4, 2007 | 03:17 PM
NHRAMAN's Avatar
Question
does your y pipe hang low on the drivers side.??????
Old Feb 4, 2007 | 03:34 PM
erikthegoalie's Avatar
unfortunately that is a sideffect of LT's with collectors....they leak at times, thats why I got an MS3...exhaust leak? :joker:
Old Feb 5, 2007 | 12:23 AM
Asmodeus's Avatar
It kinda does a little bit, but when I knocked a collector off accidently going into an automatic car wash, I went to Finish Line Performance and they reattatched everything and tucked it under some more to the point where it taps the floorboard once in a while if the rpm's drop too low leaving from a stop in 1st gear, so I know it's up as far as it will go. I can get a measurement tomorrow. It's currently stock ride height.
