Tb differences?
Old Feb 4, 2007 | 03:47 PM
STL2SLO's Avatar
Question Tb differences?
Is there any difference in throttle bodys between 98-02?
I have a 98' car and was wondering if a newer TB would work correctly on my car..
TIA
Old Feb 5, 2007 | 10:45 AM
STL2SLO's Avatar
Nobody knows if there are any differences?
Old Feb 5, 2007 | 12:57 PM
lsx24's Avatar
Yes, there's a difference. The 01 & 02 have different throttle cam, than the 98 & 99, not sure about the 00 though.
Old Feb 5, 2007 | 01:59 PM
STL2SLO's Avatar
So, can I put a newer one on my car and it still work correctly?
Old Feb 5, 2007 | 02:13 PM
lsx24's Avatar
I doubt it, but I don't know for sure. If the cams are different, I would assume the operation is different somehow, why bother to risk it.
Old Feb 5, 2007 | 04:48 PM
Smokin87TA's Avatar
Restricted User
If you have a 98-99 tb on your car, you can put a 00-02 tb on your car but you will have to switch out the cam. Its the shaft that the throttle linkage hooks to, and that goes through the tb. You have to take off the tps sensor (2)t20 torax, then remove the tb blade (2)t15 torax, Then just slide it out, put yours in and reassemble it. Tim
Old Feb 5, 2007 | 04:52 PM
TheBlurLS1's Avatar
That's what she said...
Old Feb 6, 2007 | 09:31 AM
STL2SLO's Avatar
K, thanks for the info..
 Michael S. Palmer
