manderl bent over norm.
Old Feb 5, 2007 | 05:42 PM
99huggercamaro's Avatar
Default manderl bent over norm.
do u get any more power from mandrel bent exhaust? is it worth the $? how much more power would it provide? or should i just go norm? planning on goin cam and heads next winter. im goin with 3inch to an xpipe to 2.5 all the way back.
Old Feb 5, 2007 | 05:47 PM
lsx24's Avatar
There are no published numbers, and I know of no one who has done back-to-back comparisons with mandrel bent exhaust and crush bent exhaust.
But in theory crush bent will not flow as good. You may lose a few hp up top, nothing major depending on the bends.
When in doubt always go mandrel, for nothing else other than better piece of mind. That way you know you are not leaving hp on the table.
But some people don't care if they have crush bends, claiming it makes little difference. Personally I wouldn't go crush bends because why theoretically limit your exhaust flow right off the bat, it definately reduces the potential of power.
Old Feb 5, 2007 | 10:39 PM
thanks for the info. if any1 else has anything to say id like to hear. not saying i dont like ur answer just want more info...
Old Feb 6, 2007 | 12:55 AM
Proud2bSS's Avatar
Depends on the size of all the piping AND the power potential of the motor.
I can't imagine a stock LS1 losing much power from a crush bent full 3" dia exhaust system. However, that same LS1 would lose a few ponies from a 2.25" crush bent system. I know, because I bought my SS (2nd hand) it had this sorry *** crush bent 2.25" redneck y-pipe. It was truly sad. Since then I have been running a modified MAC 2.5" o/r y-pipe on stock manifolds and it woke the car up pretty good.
I have been debating how much I would really lose if I went to LT, hi-flow cats, with 3" mandrel into a 3" x-pipe reduced down to dual 2.5" crush bent over the axle versus a dual 2.5" mandrel system (both after the x-pipe). Common sense tells me I probably would not see enough of a loss to really care. The dual 2.5" will outflow the 3" i-pipe that most people run anyway. I believe the real differences would be seen between mandrel vs crush bent before the x-pipe, which is just crazy. Just my .02....
Old Feb 6, 2007 | 05:19 PM
yeah i couldnt see losing much if any by running it like how im goin to. thanks for ur info.
