Need A Battery
Old Feb 8, 2007 | 01:23 PM
TORCHD 02 TA's Avatar
Default Need A Battery
What size do i need for my Trans Am?
I was thuinking Interstate or Optima Red
How many CCA and CA do i want. Keep in mind i just got my cam in..
What do you all think?
Old Feb 8, 2007 | 01:31 PM
2001NBMZ28's Avatar
Stock LS1 is 690 CCA according to helms, the optima red top is 720 CCA.
Old Feb 8, 2007 | 01:32 PM
saweet.. but will length and width matter????
Old Feb 8, 2007 | 01:38 PM
1997bird's Avatar
The stock battery is a group size 75, but you can a put a group size 24 into there with a little bit of work wresling it into place. I would make sure your gel cell (Optima red top) has 770 CCA, which is rated at 0* F. The CA is probably going to be about 1000 ,which is rated at 32* F. Personally I am gel cell biased, due to the longevity of the battery life over a lead acid battery.
Old Feb 8, 2007 | 01:39 PM
2001NBMZ28's Avatar
Tell them what car it's for, it'll fit. Just don't let them sell you a V6 battery, the CCA isn't as high. May not be the case with the optimas, might all be 720, least mine is.
Old Feb 8, 2007 | 01:44 PM
no one around here as optimas in stock..
So what is the most CCA and CA i can get out of an Interstate battery? My buddy has a Pro serieis 75 or somthing like that with 1000 CCA..
Help me out guys..
i may need to buy the replacemnt.. 650 CCA and 815 CA
Old Feb 8, 2007 | 01:49 PM
1997bird's Avatar
Exide makes a gel cell as well. They are stocked at NAPA for the same price as the Optima's. I have used them on several of my vehicles as well with great success. You can also find some one who handles the Champion line of battery's for gel cells.
Old Feb 8, 2007 | 01:54 PM
ok apparently AutoZone and Pep Boys are carriers for Optima..
So the biggest optima that can fit in the TA with the most CCA and CA
Also the biggest Interstate that can fit in the TA with the most CCA and CA
Thanks
 Michael S. Palmer
Old Feb 8, 2007 | 02:00 PM
TheBlurLS1's Avatar
That's what she said...
Got my optima red top from Orileys, works badass. Car seems to be a bit more responsive, I think the nearly dead battery for so long was starving the electrical system.
Old Feb 8, 2007 | 03:13 PM
HAMRHEAD's Avatar
Optima red tops are nice. Mount it in the rear and you don't need to worry about fitting it up front
Old Feb 8, 2007 | 03:38 PM
what CCA and CA Casey?
Old Feb 8, 2007 | 03:45 PM
2001NBMZ28's Avatar
Here's the vitals off of mine:
PN 27980
Model Red 75/35
CA 910
CCA 720
RC 90
Check around for a sale, Sears sells them too.
Old Feb 8, 2007 | 03:50 PM
2 autozones have the red top
One has it with 800 CCA
And
One has it with 720 CCA
Which is right?
Old Feb 8, 2007 | 03:54 PM
1997bird's Avatar
The only differance is the group size of the battery(outside diamention's).
720 CCA= 75 series, smaller and side post only(same as stock)
800 CCA= 24 series, taller & longer--top & side post
Old Feb 8, 2007 | 04:07 PM
Which one will be better though??
Old Feb 8, 2007 | 04:22 PM
grb's Avatar
grb
Get a lightweight motorcycle battery, a Braille or an Odyssey.
Old Feb 8, 2007 | 04:34 PM
2001NBMZ28's Avatar
75/35 is fine - 720 is plenty. Mine has side posts, and covers over the top posts. Fits perfectly.
Old Feb 8, 2007 | 04:36 PM
FLP's Avatar
FLP
LS1TECH Sponsor
Smile
We have that battery in stock... why don't you give us a call?
Old Feb 8, 2007 | 05:20 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Optima Red 75/35 here...nothing but praise from me. I've drained it 3 times to where it wouldn't even turn my engine over (my fault - I suck at wiring), and each time, I jumped it and it came right back to life. Tested it each and every time it happened, and it tested out great. I've had that battery now for about 3 years, still going strong.
Probably not the norm, but mine has been incredibly resilient, and starts the car every time.
Old Feb 8, 2007 | 06:25 PM
TheBlurLS1's Avatar
Mines the 75, 720cca I believe. The guy who got it for me told me they only had one size lol. It's got top and side posts. I'll use the top posts whenever I put it in the trunk later on.
