Raptor Shift Light Installation guide
Old Feb 11, 2007 | 08:30 PM
robj's Avatar
Restricted User
Default Raptor Shift Light Installation guide
Hey does anyone have this light .. I'm looking for a picture guide walkthru for the installation... also I noticed from the raptor website it says i should set the dipswitches for 4 cylinder instead of 8? What did you guys do ? does anyone have a good guide for installation?
thanks!
Old Feb 11, 2007 | 08:46 PM
dltaskull's Avatar
I just installed one, it says for a LS1 the switches should be 1-up,2-down,3-up.
I ran mine the center vent on my dash. I got all the information from Installuniversity.com, typed in shift light search. It was very helpful.
Took my like 45min. to install it. I wish i could adjust the brightness, Nearly blinded me.
Hope this helps some.
oange ss's Avatar
instructions should have cam with it...it's very simple,,red to switched power, black to ground and green to tach signal input (ECM pin #10,red connector)...yes DIP switch to 4 cyl mode
Old Feb 12, 2007 | 09:15 AM
robj's Avatar
Restricted User
thanks guys ya.. the direction that came with it dont mention that for ls1 engines its 4 cyl mode... i only saw it because i was bored online.
Old Feb 12, 2007 | 10:28 AM
HavATampa's Avatar
Helpful link for installing the Raptor Shift Light.
https://ls1tech.com/forums/showpost....55&postcount=3
Old Feb 12, 2007 | 12:16 PM
WADDISME's Avatar
Installed mine last month. Not too hard. You can follow the Harlan shift lite write-up on Installuniverstiy.com. For me, I mounted it in the defrost vent and run the complete wire out the pcm and wired everything under the hood. I have the blue led - can't miss it!!!
