Need huge HElP!! Got a missfire and tripped a code.
Old Feb 12, 2007 | 05:52 AM
litle88's Avatar
Default Need huge HElP!! Got a missfire and tripped a code.
I just changed my plugs with acdelco plugs and msd wires, My car started back firing a little and it tripped a code. I took it to the auto parts place, they read it and said that it is a miss fire from cylinder number 2. CAn someone please tell me which is cylinder number 2. Also for future reference, what cylinder numbers are on the left and what cylinder numbers are on the right. I would greatly appreciate it. thanks
Old Feb 12, 2007 | 08:02 AM
YellowMonster87's Avatar
I know this is simple, but did you absolutely make sure the plugs are all the way in and tight...? also did you by chance break a plug when you were taking them in and out...make sure there gapped correctly, and you havethe wires all the way on and connected ....other then that i dont know
Old Feb 12, 2007 | 10:04 AM
litle88's Avatar
Thanks for the response. But no sir I did not break any plugs and yes their in pretty tight. I made sure all the wires are in tight too. The problem is w/ cylinder #2, just need to know which one that is!!
Old Feb 12, 2007 | 11:02 AM
andereck's Avatar
1st cylinder on the passenger side.
Old Feb 12, 2007 | 01:14 PM
litle88's Avatar
OK got it, first cylinder is on the passenger side which one on the passenger side? But where is cylinder #2? Any help will be greatly appreciated. thanks
