Post up your Y-pipe clearance to floorpan
Old Feb 15, 2007 | 11:04 AM
black99ta's Avatar
Default Post up your Y-pipe clearance to floorpan
I'm getting a lot of exhaust noise transmitted to the cabin, and my exhaust is bone stock. It seems like my driver's side Y-pipe (the flat one) is a bit closer to the floorpan than on some other F-bods I've seen, and I'm wondering if that's the problem.
Can you guys help me out and let me know how close your driver's side Y-pipe is to the floorpan of the car? Also, can you specify if you've got a stock exhaust or aftermarket?
Thanks for your help,
Joe
Old Feb 15, 2007 | 11:12 AM
BlackScreaminMachine's Avatar
Internet Mechanic
All I can say is check the fuel lines. I havent been under my new LS1 yet but on my LT1 there was a bolt that held a bracket, it contained the fuel lines, almost directly under me on the driver side. The bolt backed out and sat on the Y pipe, made the worst vibration ive ever felt.
I used blue loctite in the stick form.
Old Feb 15, 2007 | 12:31 PM
black99ta's Avatar
I'll double check that but when I was under there I didn't see anything that was loose. It really just sounds like the pulsing of the exhaust, but way louder than most cars.
Any one else? How close are your y pipes to the floorpan?
