plug wire question HELP :(
Old Feb 17, 2007 | 04:09 PM
3.4camaro's Avatar
Default plug wire question HELP :(
I'm doing the coilpack relocation and having a hard time.
The wire ends that go to the coilpacks dont look like my stock ones and dont grasp onto the copper in the coilpack.
Is the coilpack end of a wire the same as the end that would go into a distributor? Can I interchange the two?
Old Feb 17, 2007 | 05:20 PM
TheBlurLS1's Avatar
That's what she said...
The coil pack end is the same as goes onto an LT1 opti-spark. Universal wires will work (all spark plug tips are the same), but the coil pack connector end is special. You need a set of wires, and the "Taylor Opti-Spark End Terminal Kit", which can be found here...
http://thunderracing.com/catalog/?ac...vid=3&pcid=104
Old Feb 17, 2007 | 05:26 PM
3.4camaro's Avatar
can i get the optispark deal at vatozone or the like?
