True dual question.....
Old Feb 19, 2007 | 10:02 PM
kbronSS's Avatar
Default True dual question.....
is the panhard rod reloaction kit from BMR all that is needed for the clearance to go over the axle? will it work with lowered cars(pro kit)?
Old Feb 19, 2007 | 10:22 PM
BirdmanLS1's Avatar
diff people will have diff opinions. Apparently the relocation kit is designed for those who wanna do dual 3 inch over the axle. Some guys wont even do 3 inch over the axle w/the kit. Bottom line is, i would get it to make it easier on the guy doin ur exhaust.
Old Feb 19, 2007 | 10:28 PM
kbronSS's Avatar
well i was planning on doing 2.5, is this kit intended for each pipe on each side or both on one side? i have no clue where this panhard thing goes.
Old Feb 19, 2007 | 10:30 PM
99huggercamaro's Avatar
both on 1 side..i just put 1 on 2 weeks ago and did true duels...it helps a lot for clearance.. tones of room to make sure nothing rattles
Old Feb 19, 2007 | 11:18 PM
kbronSS's Avatar
so i should be able to do it then.......what about the pro kit?
did u do 2.5 or 3?
Old Feb 19, 2007 | 11:50 PM
mines got the slp lower...worked fine
2.5 over the axle
Old Feb 20, 2007 | 01:03 AM
kbronSS's Avatar
do u by any chance have any pics?
 Michael S. Palmer
Old Feb 20, 2007 | 01:07 AM
staringback05's Avatar
with a 2.5 setup you shouldnt have any clearance issues even with a lowered car
Old Feb 20, 2007 | 01:37 AM
kbronSS's Avatar
what size would be recommended...2.5/3?
Old Feb 20, 2007 | 01:40 AM
you need to listen to them...go to ls1sounds.com and see the difference, they sound different personally
Old Feb 20, 2007 | 05:46 AM
BirdmanLS1's Avatar
how much power do u plan on making?? 2.5 is PLENTY big enough unless u want to make 500+ hp to the wheels, then it becomes a bit restrictive. Plus u get a little more low end power with 2.5 piping, a little more top end with 3 inch. I would recommend 2.5 inch for clearance issues.
Old Feb 20, 2007 | 06:36 AM
Npak's Avatar
i got me dual 3 inch over the axel w/o any problems w/o a kit. just gotta have it fabbed rather a kit.
Old Feb 20, 2007 | 03:40 PM
kbronSS's Avatar
in a couple of months my car should be done......EVERYTHING except h/c. every single bolt on including 90/90 setup and a 125shot of NOS5177. I will probably keep it like that for some time before i do a h/c.
