High flo cats vs. no cats difference
they are not all the same you get what you pay for!!
It's not back pressure it's well I'll give you a hint the letter V and speed.
I see General Motors classes are about as worthwhile as investing in their stock lmfao.
Last edited by Ragtop 99; Feb 21, 2007 at 11:26 AM. Reason: flame bait quote edited
If so, then you're as useless as the other guy.
I don't think GM is wrong, I think you misheard or misunderstood. Backpressure doesn't increase low end torque. Exhaust gas velocity and pulse timing do. The problem is that it is tough to build an emission compliant system with no backpressure. GM engineers tune the car around that fact. If the backpressure is removed as part of the exhaust work and then one changes the tuning. Without changing the tune, performance can be negatively impacted in some cases.
Loss of low end torque on some header systems is due to loss of exhaust gas velocity, not failure to acheive back pressure. In fact many headers for these car show gains in the low end.
I happen to have a top of the line header maker in my phone, he's a dear friend. Possibly have picked a trick or 2 up from him.
It won't if you propperly setup your exhaust back pressure is always bad, no if ands or buts.
Where this rumor that if you arn't lying GM foolishly pushed to you, started is many exhausts when you lose backpressure *thats a good thing* You also lose exhaust volcity and the bigger part of the puzzle scavanging.
Scavanging is why a car with headers will make more power then one thats open blocked. Esp in the whole band instead of just peak and top of the RPM band when the gases move faster due to engine speed.
So what is it, GM offers that poor a level of classes to tech or are you lieing online for crediblity? Either way it's kinda sad.
As for what I do for a living is, I am the Service and Parts manager at a GM Dealership. And we do exhaust also.
So keeping that in mind, we put headers (LT's) on a 2001 Camaro and used 3 inch pipe and a Loudmout muffler. The car actually ran worse. We went back and replaced the 3 inch pipe with 2 1/4 and the car ran suprisingly better.
There by spreading misinformation.
These cars are large motors and move a good deal of air, I'm not quite sure why a simple setup of long tubes and a mostly 3" straigh setup would hurt the car. Unless the ECU was being picking as long as the headers were of a good make and I can't off hand name a poor Long tube for these cars it should have helped the whole band.
2.25 piping would probbly be too small for a motor of this size, stock is 2.7 from what one of the stickies on this site said, and the most "choking" part is the muffler.
I also noticed on my own truck.....I put LT headers on it and fabbed my own cat-less Y and wnet into a Dynatech muffler and I also noticed I lost considerably on the low end torque. So days later I got my PCM re-tuned for a catted Y and I re-installed my 2 cats with the same header and muffler set up, and I noticed a definite increase in the low end torque and power.
These examples are what I'm basing my responses from.
I'm not trying to call names or **** in anyone's face, but it seems everytime a person posts some advice stating their personal experiance on here, then some one like "Ace Snyper" or "Caviness" responds by calling you a liar or saying that your "stupid" or your ideas "suck". Why even post on LS1Tech if others are going to go right off and call you a liar? That's what I don't like about guys like that. Why not listen to others experiance and offer your insight into it instead of tryin to make someone look like a dick?
