header leak???
Old Feb 26, 2007 | 08:25 PM
Skeletor3614's Avatar
Default header leak???
I just recently got headers installed, sounds great and all.... then took to big o to get new tires on and they said they think I got a header leak or what ever. So what are the signs that i have leak ?
Old Feb 26, 2007 | 08:51 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
you should be able to hear a ticking/whistling/leaky noise when you hit the throttle....go under the hood and rev it up first to see if the headers are leaking there or under the car at the collector.
Old Feb 26, 2007 | 08:54 PM
Default nah not that
what about a rattle noise (means something lose)???? maybe
Old Feb 26, 2007 | 09:21 PM
FireSilverLullaby's Avatar
a rattle noise is probley you headers hitting the k-member or somewhere on the floor boards. Start your car and open the hood, then feel around the header flange for hot air coming out, and listen too see if you can here a tick.
Old Feb 27, 2007 | 09:50 AM
Mac 2002 SS's Avatar
I know this may sound a little far off ,but it's true. I thought I had a header leak several months ago with alot of ticking while idling and driving down the road. I checked all my bolts and check to see if I had any cracks on my headers. Well , I decide to check my plug wires. I still had the stock plug wires with the metal end. Well, I found that one of my plug wire ends was sparking against the plug. ( burning up ). I replaced them with a set of MSD Plug wires . No more ticking
Old Feb 27, 2007 | 09:52 AM
Hennytime's Avatar
ya, ive got the same thing, under the car on the y pipe, you can hear the metalic clicking noise all the way out the rear tips. just get a big piece of pipe and tq everything down the best you can
Old Feb 27, 2007 | 12:35 PM
Z28LS1camaroguy's Avatar
yeah its sounds like really loud valve ticking, found mine when my band clamp snapped in half b/c the Y pipe came off the header and the clamp was just covering the gap.
Old Feb 27, 2007 | 02:35 PM
krink85's Avatar
i just had this problem too and i wont say which headers they were but i took it off and found that the header flange was crooked from the factory. we just used a press to straighten it out the best we could.
 Michael S. Palmer
Old Mar 1, 2007 | 09:26 PM
gyrene2003's Avatar
so i didnt do plug wires, just plugs when i did my headers last weekend, should i invest in some, and which exact msd wires are they?
Old Mar 1, 2007 | 11:56 PM
99Z28LS1's Avatar
i've been on the "header leak" valley for quite sometime, although this time its controlles and i need it otherwise more boost would prob kill the stock bottom end.
its always been on the passenger side front that made the noise. make sure everything is tight and you used good gaskets/bolts...... that was my problem
Old Mar 3, 2007 | 08:58 PM
Yes, you should buy a new set of wires. MSD 8.5mm Super Conductor Wires will work just fine or you can go with a set of Taylors 8.8 wires too. You see ,our stock wires has a metal shield on the covering the plugs ( at least mine did ). That can sometimes cause a spark against the plug itself causing a ticking noise will drive you crazy . Once I changed my wires ,problem gone and it's been several months now and no tick !!!
Old Mar 3, 2007 | 10:16 PM
ErikElvis's Avatar
I think aftermarket headers allow some engine noise out anyway. There not as thick as stock manis.
Old Mar 3, 2007 | 10:20 PM
Blk97WS6's Avatar
The bigger the header, the more valvetrain noise your going to hear. But like mentioned before run your hand over top of the header(while its cold so you dont burn your hand), check under the car where the header goes into the y-pipe, and make sure that none of the header bolts backed out on you.
Old Mar 3, 2007 | 10:26 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I wish I could hear my valvetrain better. Cam/exhaust kinda gets in the way. I know it is a sewing machine on crank for sure though.
Old Mar 3, 2007 | 11:33 PM
Blk97WS6's Avatar
