intake swap
Old Mar 1, 2007 | 02:35 PM
IronHawk's Avatar
Question intake swap
Ive got the polished lingenfelter intake on my 2000ws6-6speed.....last week i put down 421rwhp with a stage 2E head/g-1 camfrom MTI. Istill have the stock throttle body, and im wondering if the fast lsx 90 intake/90tb. combo will make a big diff. for the buck....? I also have a nitro set up as well, but have not yet tuned and tested for..... I feel that this intake is robb-in me hp. ANY advice???? thanx
Old Mar 1, 2007 | 03:01 PM
black01_WS6's Avatar
what mods do you have? It will help with this answer.
Old Mar 1, 2007 | 03:18 PM
Tainted's Avatar
yea you'll have a gain since you got heads/cam
Old Mar 1, 2007 | 05:51 PM
Red99TA's Avatar
Definitely stand to gain a good amount especially coming from an LS1/stock throttle body to a 90/90. I would say anywhere from 15-25RWHP.
Old Mar 1, 2007 | 06:40 PM
5_02ls1's Avatar
id have the weiand ported or extrude honed and use the bbk tb save you alot of money and imo you should see some nice gains
this is the main advantage of the metal intake it can be fully ported.i couldnt imagine spending 1k+ for a plastic intake and it be destroyed by a n2o back fire just my 2 cents
Old Mar 2, 2007 | 02:21 AM
IronHawk's Avatar
up-grades: asp underdrive pully, long tube cermaic hookers, mti air lid / K&n filter,85mm zo6 maf meter , smooth below, ngk tr 55 plugs, taylor wi, ...... the motor has a dual time roller set up with a ported oil pump, chrome moly push rods...
Old Mar 2, 2007 | 02:29 AM
staringback05's Avatar
if you have the money lay'n around i say go for it, it wont be a crazy amount gained...but itll be worth while
Old Mar 2, 2007 | 06:01 PM
starks1's Avatar
ithink you should just port your intake and get a throttle body you asked if it was worth the gain then the answer is no if you had a stock intake then maybe you might see 15 to 20rwhp
 Michael S. Palmer
Old Mar 3, 2007 | 06:43 AM
go for it, you can sell your intake you have now to offset the money loss.
