***Need Help***
Old Mar 4, 2007 | 02:30 PM
01blackformula's Avatar
Default ***Need Help***
My car will not start and i have no clue whats going on. One day i drove the car and it ran fine, then I went inside for a while then came back out and tried to crank the car and it started sputtering and running like it wasnt getting fuel so i changed out the fuel filter and it still didn't run after i changed it. Then under the hood the lower fuse box started poping on the fuel pump relay. I have checked all the fusible links under both boxes, and the fuel pump is new. What else should i do?
Old Mar 4, 2007 | 02:35 PM
2xLS1's Avatar
Security LED on? Know anyone with tuning software that can try turning off the VATS?
Old Mar 4, 2007 | 02:37 PM
No and no.
