Water temp guage
Old Mar 4, 2007 | 03:51 PM
motomike734's Avatar
Default Water temp guage
i bought an aftermarket one where do you put the pieace that goes into the engine? i have a 00 z28.....
Old Mar 4, 2007 | 04:07 PM
Frosty's Avatar
There's a spot on the back of the passenger side head, or you can drop the starter and take out the plug there. Do a search, there's some write ups on it floating around.
Old Mar 4, 2007 | 04:27 PM
gman's Avatar
You can also drill and tap the thermastat housing and mount it there. I ended up just using the passanger side head, it seemed to be the easiest solution.
Old Mar 4, 2007 | 04:29 PM
b4ckid02's Avatar
i also use the passenger side head
Old Mar 4, 2007 | 04:42 PM
99Hawk262's Avatar
I bought a T-fitting from Lowes and did a dual purpose water temp sending unit mount/throttle body bypass. It was easy and simple.
