02 sensor questions
Old Mar 4, 2007 | 05:31 PM
iroc85blu's Avatar
Default 02 sensor questions
just did qtp headers on my ta and cant seem to get the o2's out of the exhaust manifold and y-pipe. Starting to strip. I only need the fronts because im running sims. Any solutions to getting these out. Also are the rears the same as the fronts or are they interchangeble. So i could use the old rears for the fronts.
Old Mar 4, 2007 | 08:02 PM
98Camarod's Avatar
The fronts are different from the rears. All you need is a 7/8 wrench and it should come right out. I wouldnt spray any penetrating lube in there because it may or may not damage the o2 sensor.
Old Mar 4, 2007 | 08:06 PM
phoenixv8's Avatar
I thought they were the same as the fronts, they have the same part #.
Old Mar 4, 2007 | 08:17 PM
98Camarod's Avatar
Ha, I meant to type aren't.
