Motor Mount Question...
Remove my air and egr?
I already have both headers off so I have the air removed to the point of where the hose is running on the driver side fender down below the fuse boxes to some sort of "air motor". How do I get that thing out from under the fuse boxes.
The egr part is still connected to the throttle body at the top. How do I get this off of there? It seems pressed on.
Unbolting the whole thing should give you enough room to get the big bolt out by sliding it around in there instead of removing accessories.
Have you done it that way?
It seems much easier, but I don't know if the mounts are angled weird or whatever to prevent them prom pivoting.....
The EGR should be connected to the manifold, behind the TB. Unbolt it from the exhaust, and remove the single bolt from the manifold. Then you should be able to unplug it from the harness and pull it vertical out of the manifold. Go buy a 1-3/8" adjustable freeze plug from Autozone and put it in the manifold to plug the hole.
I unbolted the passenger side pedestal and slid it backwards, then it let me get the big bolt out without removing the compressor. The pedestal just chilled in there, because it wouldn't fit down through the hole, but I didn't need it to. I put the new mount in the clamshel, stuck it back up there, bolted it back to the pedestal, then bolted the pedestal back to the k-member.
I have the driver side motor mount and header completley done. I have the big 18mm bolt out of the passenger side and the top 2 of the 4 bolts holding the clamshell to the block broken lose. I can't get an angle to break the bottom 2. Any suggestions on how to get leverage to break these? The passenger side seems to be a bitch compared to the driver side. I am thinking of waking up tomorrow and using an impact to break them so let me know if there is another way.
With enough wobble head extensions and swivels, I could change out a solar panel on the Hubble telescope from my bedroom.
1. My pcv valve is broke where it 90 degree angles at the back of the driver side valve cover. (this is very typical of 98's with around 100k from what I've read). I finally realize that this has caused some of my oil consumption (about a quart every 3,000 miles and also its been causing my dipstick to jump out an inch after every time I push back down into place). Can I drive like this till I fix it?
2. My dumb@$$ broke the coolant temp sensor at the front of the drivers head during all this installation and removal. I think I can rig it until I get a replacement but if the rigging doesn't work with I still be ok to drive for a bit without a working sensor. All I will lack is the temp gauge right?
http://i19.tinypic.com/4g3mn8i.jpg
http://i16.tinypic.com/2pyny2o.jpg
You should not really operate the car without a working temp sensor. If you broke the plastic part off, and the prongs are still attached, you can JB weld it back together and rock out (mine's done this way lol). I broke my replacement installing it, and the dealership was closed, so I improvised. Been driving great ever since.
The reason I say you shouldn't drive it without a sensor is that it doesn't just tell the guage what temperature the car is so you'll know, it tells the PCM too. The ECT (engine coolant temperature) governs about half the damn tables in the PCM. Your fueling, open loop/closed loop, idle speed, etc. all vary with the coolant temp, along with god-knows how many others.
Y pipe
o2's
Random bolts and pieces
Coil Packs
Wires
Air Induction
Plug Egr and pull Air Pump
3 hours for removal of exhaust and related parts
3 hours for installation of exhaust and related parts
10 hours for motor mounts take off and put on.
Now given I had to do this again I know I could get it done in about 6-8 hours as I have learned a ton of little tricks during this.
