Fast 90mm Map Sensor Fix
Old Mar 8, 2007 | 04:45 PM
lm7's Avatar
lm7
Default Fast 90mm Map Sensor Fix
So its agreed that the map sensor location and mounting(non-exsistant) on the fast manifold is crap. how did you fix yours? im about to take my manifold back off but i want to fix this problem once and for all. is it just suppose to seal and stay put with magic? WHAT GIVES? for those that havent seen it it's just a small size hole which is kind of close to the size of the gasket for the sensor and thats it, it kinda just floats there and you hope it seals.
Old Mar 8, 2007 | 05:43 PM
DuronClocker's Avatar
Drill/tap that hole for a 90 degree 1/4" hose barb. That's what I'm going to do if I have any issues.
Old Mar 8, 2007 | 05:44 PM
Red99TA's Avatar
I painted my FAST so it's got multiple layers of paint on it so that made the fitment of the map alot tighter...no issues here.
Old Mar 8, 2007 | 06:47 PM
SSwanner's Avatar
i made a C clamp out of aluminum sheet metal. about 1" wide with a hole in the bottom side of it. just use a longer bolt in the center bolt and slide the C clamp on and put a nut on the bottom of it. the top holds the map sensor in the intake. pretty much idiot/fail/blow proof.
Old Mar 8, 2007 | 06:51 PM
lm7's Avatar
lm7
pics? i think iget the idea, PITA on f bodies for trial and error especially with coil pack relo kit EVERYTHING IS COMING OFF.
Old Mar 8, 2007 | 08:01 PM
iamsickofitall's Avatar
RTV it in there. it's painless. i used black and have no vacuum leaks or anything of the sort
Old Mar 8, 2007 | 08:14 PM
purdueranger's Avatar
same here
Old Mar 8, 2007 | 08:28 PM
ls2 bait's Avatar
i did that on my ls6 2 yrs ago and ive never had one issue. the clip on my ls6 was broken.
Old Mar 8, 2007 | 09:46 PM
Michael02hawk's Avatar
What about using the little bracket included with this kit from LPE:
http://www.lingenfelter.com/Merchant...Category_Code=
I know, I know, its too expensive for just the 1 bracket, since we wont be using the rest of the kit on our LS1's, but I'd be curious to know if this bracket fits right, and if LPE would sell just the one part to us LS1 owners???
Old Mar 8, 2007 | 10:51 PM
TheBlurLS1's Avatar
That's what she said...
If you go to the dealership, you can buy the little rubber piece that slips over the MAP sensor, it's like $5. With a new one of these, it fits much better.
I tried RTVing mine, but it just got knocked loose.
Old Mar 9, 2007 | 12:11 PM
lm7's Avatar
lm7
im gonna get a new gasket for sure, a couple of guys i know are talking about a remote mounting solution....im gonna look into it.
Old Mar 9, 2007 | 12:15 PM
DirtyJohn's Avatar
I wrapped some teflon tape around mine and plugged it in.
It's pretty secure, I hope.
Old Mar 9, 2007 | 12:54 PM
ApacheDrill's Avatar
just tape it down with electrical tape, you wont see it anyway
Old May 1, 2007 | 02:39 PM
aNuBiS's Avatar
Do you have the part number for this? I tried going to the dealership, and they told me I couldnt buy the rubber peice seperate from the MAP.
Old May 1, 2007 | 04:58 PM
vettenuts's Avatar
The number I got for the Vette (assume f-body is the same) is 16194007
I also just put up photo's of the way I did it on CF, here's the link:
Link
Old May 1, 2007 | 05:03 PM
aNuBiS's Avatar
Yup thats the good part number
Old May 1, 2007 | 06:34 PM
JakeY2KZ's Avatar
that's some bs. I had my g/f go into our local dealership to order mine (I'm deployed) and they had no problems getting it on order. I just told her to tell them its the seal/gasket for the Map sensor. $4 plus some change.
