slp header install?
Old Mar 10, 2007 | 11:48 AM
allthrotle's Avatar
Default slp header install?
Im trying to put my slp headers on and they're not wanting to fit right, the driver side is hitting the steering shaft, and the passenger side is hitting the lower control arm. Does anyone who has these headers or installed them have any tips or tricks as to how to put these headers in?
Old Mar 10, 2007 | 12:38 PM
allthrotle's Avatar
Anyone?
Old Mar 10, 2007 | 08:59 PM
gtoroadracer's Avatar
What year, make and model car do you have? From what you wrote so far it sounds like either a motor mount is busted or the frame might be tweaked.
Old Mar 10, 2007 | 10:27 PM
gollum's Avatar
On drivers side the SLP header install is easy and will not hit steering shaft...your car is probably not raised high enough to install them. On the passenger side you will have to loosen rear transmission mount and lower rear of transmission for install clearence.
