throttle body question?
Old Mar 10, 2007 | 07:56 PM
01BlackCamaroSS's Avatar
Default throttle body question?
What is the biggest size throttle body that you can bolt on to a ls6 intake manifold?
Old Mar 10, 2007 | 08:26 PM
02silvaZ's Avatar
not much since bolting up anything bigger than stock cause the LS6 manifold only has a 75mm opening, i would suggest a port and polish on the stocker, it is a 75mm also, perfect match up
Old Mar 10, 2007 | 10:13 PM
Red99TA's Avatar
90mm...TPIS sells an LS6 intake where they cut the original opening off and mold in an opening that will fit 90mm TB's. Personally I would just pay the extra couple hundred for a FAST 90.
