Idle Problem ? H E L P !
Old Mar 11, 2007 | 04:52 AM
Mohammed's Avatar
Question Idle Problem ? H E L P !
I was trying to take out the Intake manifold , when I got to the last two bolts I didn't have the long socket wrench to take them off , so I decided to put everything back . After that, I started the car and it was idling so bad like there is a big cam and rpm goes down to .5k . The car acts like it's going to stop ,
what the hell happened ???!
Old Mar 11, 2007 | 05:23 AM
mcamarols1's Avatar
Did u torq the bolt back in in the proper sequence, and to the correct torq spec?
Old Mar 11, 2007 | 05:30 AM
Mohammed's Avatar
Yes , but without the torq specs
any ideas !?
Old Mar 11, 2007 | 06:23 AM
RA4926's Avatar
you probably didnt torque them down enough and have a vacuum leak. losen them all up get a torque wrench and torque specs and do it right.
Old Mar 11, 2007 | 08:22 AM
Red99TA's Avatar
follow the right sequence of tightening the bolts too...do a search to find it
Old Mar 11, 2007 | 10:33 AM
Mohammed's Avatar
I loosened some bolts and the car is ok now , I don't have a torque wrench right now ,,
!! not using a torque wrench caused this !! WEIRD !!
thanks anyway guys
Old Mar 11, 2007 | 10:38 AM
dpw41285's Avatar
thanks anyway guys
there is nothing wierd about it, out cars are very sensitive to unmetered air. go ahead and tighted down rod bolts with out a torque wrench!! WEIRD !!
