Lid Question
Old Mar 18, 2007 | 07:07 PM
LS1tones's Avatar
Default Lid Question
Ok, Im installing a new whisper lid, only problem is that I cant get the MAF out of the old airbox. Is there a trick to doing this? I have tugged on it for a while now, and it has started to turn a little but it just wont come out.
Old Mar 18, 2007 | 07:15 PM
00slowredz's Avatar
did you take off everything up to the throttle body? mine came off pretty easy i just moved it side to side a few times and it popped out
Old Mar 18, 2007 | 07:20 PM
740racing's Avatar
Keep twisting and pulling, I had a hell of a time with mine too.
Old Mar 18, 2007 | 07:24 PM
LS1tones's Avatar
I have it the whole thing off up to the TB, the old bellows are off and its just the airbox left. Its pressed in there I couldnt budge it when I first took it out of the car. I brought it inside to warm up a little hoping that would help, but no luck so far.
Old Mar 18, 2007 | 07:55 PM
SweeTbone's Avatar
I used a hair dryer to warm it up and it came right off.
Old Mar 18, 2007 | 09:32 PM
00slowredz's Avatar
wow, i didnt think it would take that much to get it out. mine came out REALLY easy
Old Mar 18, 2007 | 09:39 PM
98Camarod's Avatar
Yeah, mine was pretty easy too. I took the one off of my suburban and that sucked, but it still came off with some twisting and pulling.
Old Mar 18, 2007 | 09:41 PM
00slowredz's Avatar
yea im pretty sure twisting is the key ingredient
 Michael S. Palmer
Old Mar 18, 2007 | 09:42 PM
hawaiianpunch01SS's Avatar
ya just pull nothing special to it!! mine took alot of force 2! just be careful it is an expensive part!
Old Mar 18, 2007 | 10:42 PM
LS1tones's Avatar
I have been twisting and pulling this for a couple hours, and it has not even budged. I can only twist it about 2 degrees because of the anti twist key pieces on the MAF and airbox. I even had myself on the MAF and my buddy on the airbox and it still has not moved at all. it seemed a little more plyable under heat, but still wouldnt come out.
I think its going to meet the dremel tomorrow after I get home from work.. cause at this point Im sick of screwing with it. I did 4 sets of break pads in less time than I have played with the MAF sensor.. and I still have not taken the air sensor out either.
Old Mar 19, 2007 | 12:33 AM
ls1lover346's Avatar
i had the same problem with mine, i cut the part of the old air box where it connects to the MAF, it came out real easy after that!
Old Mar 19, 2007 | 12:40 AM
Formula_X's Avatar
Mine took me a while to get out too, it wasn't budging. I ended up using a hair dryer like someone else stated in this thread, that got it considerably looser... that combined with LOTS of twisting eventually got it out.
Old Mar 20, 2007 | 09:22 PM
WILWAXU's Avatar
You could just take the car for a drive. The warmer the plastic the easier it comes apart.
