Header hitting the steering shaft!!
Old Mar 20, 2007 | 12:19 AM
True Performance's Avatar
Default Header hitting the steering shaft!!
i have the obx headers(dynatech copys) and the steering shaft is hitting the driver side header... steering the car is not fun lol. any suggestions on what to do?
Old Mar 20, 2007 | 12:25 AM
Specialized's Avatar
hit it with a hammer!
Buy QTP/Kooks next time? I don't know. I havent heard of anyone else complaining about this issue. Is your motor mount shot?
Old Mar 20, 2007 | 12:42 AM
TheBlurLS1's Avatar
That's what she said...
You can adjust the steering shaft a bit. Loosen the top bolt and slide it down. If that doesn't work, poly motor mounts will raise the motor a hair, and you should have done them from the beginning. If THAT doesn't work, dent the primary.
Old Mar 20, 2007 | 12:45 AM
hawaiianpunch01SS's Avatar
ya go with the hamer idea!! lol is it possible that it is a bad or defective header? just a thought anothe guy posted on hear were his header rubed through his oil filter turned out to be a defective header they sent him a new one and problem solved! just a thought
Old Mar 20, 2007 | 12:51 AM
cowboysfan's Avatar
I have kooks and my where hitting when I installed headers. I did what TheBlurLS1 suggested. plus did have to on headers just a bit. poly mounts are going in when I return from dessert. when I stomp on it, the motor lifts a little so thats not an issue, it's when around that I used to feel it. checks 4.0 now...
fuerzaws6
Old Mar 20, 2007 | 12:56 AM
well i emailed them today about it, hope they will do something. ill try to adjust the steering shaft and as a last resort ill beat the headers with a hammer, just hope i dont get carried away lol. they have been a nightmare to install too
Old Mar 20, 2007 | 08:38 AM
miamifan3413's Avatar
I had the SAME prob......check this thread out, maybe this will help:
https://ls1tech.com/forums/showthrea...tting+steering
Old Mar 20, 2007 | 10:03 AM
z34_nut's Avatar
What other problems did you have, Joey? Did you actually bang on the LT or what?
 Michael S. Palmer
