Oil pump install?
Old Mar 22, 2007 | 11:46 AM
PunkNPonys's Avatar
Default Oil pump install?
I am doing the dreaded oil pump install this weekend and i want to make sure i have everything i need. Am i going to need all new gaskets or can i reuse my old ones? I know i need a new crank bolt and all the fluids. Am i missing anything? Thanks in advance.
Old Mar 22, 2007 | 01:45 PM
marv's Avatar
You'll need new WP gaskets since it's got to come off. Also will need a front cover gasket and a crank seal. Some folks reuse the front cover gasket, but I've always replaced them. Make sure you have the right o-ring btw.
That with the proper fluids should just about do it.
Old Mar 22, 2007 | 01:48 PM
brad8266's Avatar
You can get away with reusing the front cover gasket and crank seal, but I like to replace them personally. You also need a new oil pump o-ring and water pump gaskets. Get threadlocker too.
Old Mar 22, 2007 | 01:50 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
im getting ready to do mine two my waterpump gaskets are metal and like a month old do i need to replace them still
brad8266's Avatar
Might as well for 9$
Old Mar 22, 2007 | 01:51 PM
LS1Tech Sponsor
thanx
Old Mar 22, 2007 | 02:53 PM
bczee's Avatar
You will need a new front seal.. GM state that.. I tried to re-use mine once.. and it leaked..
The rest of the Metal / O-Ring ones can be reused. But as long as you have it apart.. replace what you can for a few $ more.
Old Mar 22, 2007 | 08:21 PM
PunkNPonys's Avatar
Well i guess i will replace all the gaskets. How do i know if i got the right O ring for the pickup tube, the one i got is blue. Do i need to replace the timing cover gasket? Is it metal or paper?
 Michael S. Palmer
Old Mar 22, 2007 | 11:56 PM
TheBlurLS1's Avatar
That's what she said...
O-ring that came with my new oil pump was blue, I was wondering the same thing, but it worked great.
I replaced my timing chain gasket when I did mine, I suggest you do the same. It's metal, with a rubber o-ring like material around the inside. Check LS1howto.com's cam swap section for more info, also part numbers listed on the main page (look at the top).
