ground wire?
Old Mar 23, 2007 | 10:11 PM
Timonator's Avatar
Default ground wire?
Can someone tell me where the ground wire that is part of the alternator harness goes?The long flat ground wire.
Old Mar 24, 2007 | 12:07 AM
White_Ls1's Avatar
I believe it connects to the driver side frame.
Old Mar 24, 2007 | 12:11 AM
brad8266's Avatar
drivers side frame.
Old Mar 24, 2007 | 01:08 AM
TheBlurLS1's Avatar
That's what she said...
Actually, there's two, and one bolts to the block, below and forward of the driver side motor mount. 10mm head on the bolt for it. Wiring harness that runs down there has the exciter wire, ground strap(s), and the bank 1 O2 sensor wires.
There's another one that does bolt to the frame, forward of the ABS module bracket's lower front bolt.
Old Mar 24, 2007 | 08:10 AM
Timonator's Avatar
I know about the one that bolts to the block.I was talking about the one that bolts to the frame somewhere.
Old Oct 23, 2007 | 10:36 AM
ls1ws9ta's Avatar
any part number for the ground wire?? Mine is torn is half??
