Stainlesworks Chambered catback
The quality of the parts is good and the 3" clamps they provide are good as well. It's just that the damn thing comes in so many parts, it's hard to get a proper fit and alignment. Plus, the exhaust hangers they use are held in place with 3" clamps. The tips slip over the chambered pipes and had such a loose fit, we couldn't get the clamps tight enough to keep them on. We ended up having to weld them to keep them from falling off.
After we had the system pieced together, we couldn't get the tips to align in the openings properly (I have a WS6). We could get one tip centered in the opening fine, but the other would be pointing in some odd direction. It had to do with the "Y" type pipe directly after the axle. It didn't seem to be angled properly that would allow both tips to exit correctly. We spent hours on trying to align the tips. The only solution that allowed each tip to look as though they exited the same, was to angle each tip down so that they hung below the bumper (there was a good 4" gap between the top of the tip and the opening). They looked stupid and if you stood at the side of the car (a few paces back) you could easily see the chambered pipe hanging below the car.
We also had a problem with the chambered I-pipe. It kept smacking against the floor board toward the rear of the car (under the rear passenger seat). The pipe over the axle rubbed as well.
I eventually ended up taking it to a custom exhaust shop and had them align it, fix the hangers, add a wedge here and there and weld it all together. It looks great now, but the frustration wasn't worth it.
As far as the sound goes... it's not as raspy as a GMMG. It still has a nice deep tone to it and will definately get attention. At least I like that part of it. There's no drone that I've noticed. I have headers and a catted Y-pipe going on in a few weeks and suspect it'll sound even better.
So, in closing... had I spent full price and had to dick with everything I did... I'd be pissed. But, I spent 50% on the system and couple hundred getting it aligned properly. I still ended up paying less than the system costs at full price.
As with most things LS1 related... YMMV.
Good luck,
Marc
