Will an LS6 intake work off a.....?????
Old Mar 28, 2007 | 05:36 PM
CBRAKLR85's Avatar
Default Will an LS6 intake work off a.....?????
so the question is will an ls6 intake off of a 04 gto work on my 00 z-28? is there any thing i need to know when installing?
thanks for the help
TJ
Old Mar 28, 2007 | 05:40 PM
LostCauseZ06's Avatar
yep, it will bolt right up
Old Mar 28, 2007 | 05:43 PM
you will need coolant pipes for the front btw... and will need to delete your EGR and get block off plates.
Old Mar 28, 2007 | 08:32 PM
CBRAKLR85's Avatar
i plan to remove all of the egr. but where do i get the coolant pipes from are they different than what i already have?
Old Mar 28, 2007 | 08:34 PM
Tainted's Avatar
you dont need the coolant pipes, but if you dont use the LS6 lines you have to cut off the ribs on the underside. the ls6 arent any better or any worse so i kept my ls1 lines and cut my ribs off
02silvaZ's Avatar
+1
