Just got it iN!
Old Mar 29, 2007 | 12:08 PM
blackbirdls1's Avatar
Default Just got it iN!
Well I just got my pacesetter longtubes in and everything looks good. I need to order what I'm missing. I got the ones for 00-02, not the race ones so do I need to buy and block off plates and if I do which ones? THere are two connections on passenger side and one on the driver. Which one do I need to block off. Basically I want to order everything else at once so it all gets here around the same time. I'm getting the GM manifold gaskets so far.
Old Mar 29, 2007 | 12:13 PM
Blacker's Avatar
There is a connection for the AIR System on each header. If you are not using the AIR, then you will need the block off plates. On the passenger side header, there is a connection for the EGR. You will need the block off plate for this since you do not have EGR. Sme places sell this as a kit and I bought mine at Pace Parts. Make sure you get some gaskets as well.
Old Mar 29, 2007 | 12:26 PM
Renegade's Avatar
You can get the parts needed to block EGR and AIR at http://www.speedinc.com they are a sponsor here.
Good Luck
Old Mar 29, 2007 | 01:47 PM
I have a stock car with just a lid. It's and 01 so I'm assuming Air is on there. So just buy that kit? Edit: In the box of bolts and stuff there is a block off plate in there, just one, so I should be fine then.
