What temp should 160* t-stat run at?
Old Jun 12, 2007 | 03:54 PM
LilJayV10's Avatar
I have a 2000. The guy before me put a 180 thermostat in it. He said he didn't have a tune on it and the temp gauge sits right about 180. The computer doesn't learn something like that does it?
Old Jun 14, 2007 | 05:46 PM
Unstang's Avatar
I have a 160* thermostat, I was wondering if lowing my fan activation temp would lower my coolant temps...
Today it is 90* outside, I just drove 15 minutes in traffic, city driving. My aeroforce scan gauge showed my air intake temp as 115* & my coolant temp @ 212*, my fans are on & functioning fine.
Is this anywhere near normal?
Old Jun 14, 2007 | 05:53 PM
lsx24's Avatar
Yes, reprogramming the fans will lower your coolant temps. Anywhere near or over 200* is too high if you have a stat. I bet your fans aren't coming on till well after 200*. When I had a stat, I had my fans programmed to keep coolant at 185* at all times. That is a known acceptible temperature.
Old Jun 14, 2007 | 05:55 PM
lsx24's Avatar
No the computer doesn't learn something like that. The fans need to be programmed.
99-02 don't have accurate temp guages. They are dummy guages, and will read the same temp, even though your coolant temp can vary alot. 98s are the only ls1 fbodies that have accurate temp guages.
Old Jun 14, 2007 | 08:58 PM
slowmaro61's Avatar
im thinking about getting a new 160* to, how do i adjust what the fans kick in at?
Old Jun 14, 2007 | 10:34 PM
Unstang's Avatar
I dicked up when I had my tune done, I told them that fans came on a stock temps, I think they heard it as make the fans come on @ stock temps.
I have a custom tune from LS1 Edit, can I change the fans with the Predator that came with my car? I've never had it hooked up or used one...
Old Jun 15, 2007 | 12:08 AM
chevyls1's Avatar
From: where ever i can store my car. (palos hills,il for now)
Mine Does That To It Runs Like 180
Old Jun 15, 2007 | 08:11 AM
lsx24's Avatar
How do you know it's running at 180? You have a 2000.
Old Jun 15, 2007 | 08:12 AM
lsx24's Avatar
Through some tuning software. The most popular and recommended is HPTuner. A tuner in your area will usually do it for you for $100 or so, or you can buy the software yourself for $400.
lsx24's Avatar
I don't know if you can do that with a predator. Last I heard the answer was yes. Might try posing in the tuning forum where you will get better responses.
Old Jun 15, 2007 | 09:11 AM
chevyls1's Avatar
that what i was told it runs around
Old Jun 19, 2007 | 12:04 PM
  #32
SpdFrk1990's Avatar
Also besides just lowering the fan temps you will want to lower the Idle learn min temp (B4501) Factory setting is 176 im lowering mine 20 degree's with the 160 stat. This was per SSpdDmon.
Old Jun 19, 2007 | 12:59 PM
  #33
That_guy's Avatar
Originally Posted by SpdFrk1990
I really want a 160 degree stat I hate how hot it is under the hood running at 210 with headers. I have efilive and can tune it for the cooler temps. Where is the best place to get the 160? Also what temps should I set my fans to you think??
just go to slp or summit or ---------> sponsors also sell them
Old Jun 19, 2007 | 01:17 PM
  #34
SpdFrk1990's Avatar
Alrdy ordered one from summit yesterday.
