tb question
Old Apr 3, 2007 | 12:05 AM
chuy10's Avatar
Default tb question
how do u port a throttle body thanks also does a tb spacer give me any more hp thanks for help
Old Apr 3, 2007 | 12:07 AM
Screaminchiken's Avatar
Take it to a machine shop, you can get it done fairly cheap, and for your 2nd question, nothing you would notice.
Old Apr 3, 2007 | 12:09 AM
get an LS6 intake manifold and tb first, no point in porting stock tb unless you plan to do !EGR
Old Apr 3, 2007 | 08:43 AM
WADDISME's Avatar
Old Apr 3, 2007 | 08:48 AM
ls1amit's Avatar
I did mine last night. Things to do is smooth out the lips with a dremel and get grind down the bump stop so you throttle body opens 90 degrees. I was bored and we bolted it off ported it put it on easy 3 hour job if your quick. Dont touch the blade either. I did a mild port job and i noticed much better throttle response not to sure about the full throttle gain but im sure its there I just wont feel it on the but dyno. I still have to do the tb bypass as well.
