will an aftermarket intake lean me out
Old Apr 3, 2007 | 04:20 PM
Sluggish's Avatar
Default will an aftermarket intake lean me out
the PP typhoon intake and throttle body had been ordered(85/85) . my car has been dyno tune...will it lean out when I put on this better flowing setup.
Old Apr 3, 2007 | 05:18 PM
Red99TA's Avatar
Yes although going from an LS6 to this setup isn't a drastic change in airflow you will still benefit from retuning to take advantage of the increased airflow. When I put on my FAST 90/90 I was definitely leaner than before especially in the cells above 5K rpms.
Old Apr 3, 2007 | 05:19 PM
black01_WS6's Avatar
your idle may go up a bit, as you have more air flow. I would throw it on the dyno to see what the A/F is. I would probably get a retune- talk to your tuner and work something out- you don't need a full tune.
Old Apr 3, 2007 | 05:35 PM
Sluggish's Avatar
I'm going to get it tuned again. I was just wondering about driving it around before I could make it over there.
Old Apr 3, 2007 | 05:36 PM
Red99TA's Avatar
You'll be fine driving it over there. Like I said mine only got too lean at high rpm's. Just don't beat the crap out of it on the way to the tuner.
