LS6 Manifold Question.
Old Apr 4, 2007 | 10:25 PM
DeadLifter's Avatar
Default LS6 Manifold Question.
The manifolds on the 04 GTO's are just a normal LS6 manifold aren't they? Will this be a direct bolt on to a 98 minus EGR?
Old Apr 4, 2007 | 10:57 PM
mvvette97's Avatar
Yes but you will need to grind the fins down on the bottom of the intake. Doing this will let the coolant lines remain in place so the intake will bolt down fine.
Old Apr 4, 2007 | 11:16 PM
DeadLifter's Avatar
Thanks for the help.
I even found a kit that lets you keep your EGR hooked up.
