electric water pump and fan question
Old Apr 5, 2007 | 09:58 AM
ss2000's Avatar
Default electric water pump and fan question
I just installed mezieres race version ewp. Do I need to do anything for the electric fans? I drove it a little since I got the car back together and the temp. held around 200 degrees. I didn't hear them kick on but the car didn't get any hotter.
Old Apr 5, 2007 | 10:00 AM
MeentSS02's Avatar
Kleeborp the Moderator™
What temp do you want it to run at? What temp thermostat are you using? The fans will only be used while the car is sitting still (staging lanes and such) to keep the temps down.
Old Apr 5, 2007 | 11:28 AM
ss2000's Avatar
The race pump has no thermostat, I just want to be sure the fans will still kick on.
Old Apr 5, 2007 | 02:54 PM
MeentSS02's Avatar
Oh yeah...fans will still kick on. They are controlled by the PCM (unless you have wired up an additional switch), so they'll come on at a set coolant temp (which is really high if you have the stock settings).
