Oil pan replacement
Old Apr 9, 2007 | 08:23 AM
TN94Z's Avatar
Default Oil pan replacement
I know this has been talked about but I can't seem to find it when I do a search. Can I replace the oil pan on my 98 TA without pulling the motor? It has a small crack in it and I need to replace it. Thanks
Old Apr 9, 2007 | 11:47 AM
00BlueTA's Avatar
Yah you can change it without pulling the motor. I had to change the pan gasket on my camaro, you have to drop the K-member down a bit to let the pan clear the crank but thats about it. It sound hard but its not, just take your time and make sure the new pan and gasket doesnt leek.
Old Apr 9, 2007 | 12:07 PM
TN94Z's Avatar
Did you just use an engine hoist to hold the motor up or something?
