Cooling Question
Old Apr 10, 2007 | 01:42 PM
TUCKZ28SS's Avatar
Default Cooling Question
Anyone got an idea, my car runs pretty warm and the only thing i can think is i have ground effects and POSSIBLY the air isn't getting pulled up underneath properly into the air dam? Lets not hear the "I don't like ground effects thing" I need info not opinions.
Old Apr 10, 2007 | 01:44 PM
staringback05's Avatar
if your front valance is lower then the air damn...yes...it will block some flow....also remember however that, the gauge isnt exactly right
Old Apr 10, 2007 | 01:47 PM
TUCKZ28SS's Avatar
how far off i have the 160 tstat and the car gets up over 200 pretty easy, i have a tranny cooler in front of the radiator, not sure if that is also causing some issues
Old Apr 10, 2007 | 01:50 PM
a tranny cooler will block some flow also but its designed to not effect the radiator that much.....i have one....
you might want to check that stat....aftermarket stats fail faster sometimes...also check your fans and what there coming on at....check your fluid level to and make sure you dont have any air bubbles
