Got some DTC's after cam install
Old Apr 11, 2007 | 03:23 PM
kevins2000LS1's Avatar
Default Got some DTC's after cam install
I have a 2000 6 speed Z28 and just did a cam install, i know some of what the codes are, but theres a few that has got me. Heres what i got Pacesetter headers Non-emission that should be the problem for a few of the codes. No rear o2, im waiting to do a dyno tune so i will have the fixed then. Also all the EGR and AIR has been removed, But i will list all and maybe you guys can help me :
P:0121 - Throttle Pos. Sensor/Switch A Circ Range/Perf -- Whats that mean?
P:0135 - Oxy Sensor Heater Circ bank1, Sensor-- Whats that???
P:0140 - Oxy Circ No Activity Dect. Back1 Sensor 2-- Thats the rear o2's
P:0160 - Oxy Circ No Activity Dect. Back2 Sensor 2-- Same as above
P: 0300 - Random/Multiple Cylinder Misfire Dectected-- Is the cam causing this???
P: 0327 - Knock Sensor 1 Circuit Low input Bank1, 1 sensor-- Whats this mean???
P: 0405 - EGR Recirculation Sensor A circuit low-- The Egr has been removed form car thats the issue here.
P: 0412 - SEC AIR Injection System Switching Valve AICR ERROR- All the AIR has Been Removed Also, I think thats whats causing this
P: 1404 - EGR Closed POS PERF-- Again EGR has been removed
PLEASE CHIME IN
Old Apr 11, 2007 | 03:25 PM
Thats the ones im worried about, the others i kinda think i know what they are.
Old Apr 11, 2007 | 07:45 PM
Will A Tune Help??
Old Apr 11, 2007 | 07:52 PM
09CPTN's Avatar
I can't see how a tune could hurt.
Old Apr 12, 2007 | 03:05 PM
35thUCF's Avatar
a tune will get rid of all your troubles, if you can find someone with HP tuners, you can change the parameters that cause many of those codes
Old Apr 12, 2007 | 06:59 PM
Yeah i talked to my tuner today and he said to fix the 1 o2 code and the knock sensor and he could handle the rest
