View Poll Results: Waterpumps: GM OEM vs. Napa vs. Advance Auto vs. Autozone vs. Other
GM OEM
65.69%
Napa
6.86%
Advance Auto
5.88%
Autozone
7.84%
Other
13.73%
Voters: 102. You may not vote on this poll
Best Waterpump: GM vs. Napa vs. Autozone vs. Advance vs. Other
Old 09-26-2006, 03:05 PM
Tech Resident
ChocoTaco369's Avatar
Default Best Waterpump: GM vs. Napa vs. Autozone vs. Advance vs. Other
well, my water pump is leaking. what a joyous occassion i'm now searching to buy one for my car. it's a very small drip, but i'd like to get it replaced before it pukes everywhere. i'd like to know what water pumps you guys have had the best luck with, a GM OEM pump, a pump from autozone, advance auto, napa, or anywhere else. note that money is NOT an issue - i can get all these pumps within $10 of each other so i'm not worried about the additional few dollars. also note that i do not want an electric water pump. this is not an option to me. they're far too expensive, don't last very long, are added strain on my electrical system where i already run a sub and an amp and it's just not worth the hassel for a lousy ~10 horsepower.
lemme know what you guys like. i want the best water pump for longevity. i don't care about warranties or anything other than the basic 1 year or so. the longest warranty is useless to me if i have to replace the thing every 5,000 miles
Old 09-26-2006, 03:06 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
GM-OEM.
Old 09-26-2006, 03:24 PM
RrCoX22's Avatar
GM OEM of course but I hope you like paying "CASH-O-RAMA"
normally autoparts stores will have GM OEM parts though (just in their name)
Old 09-26-2006, 03:29 PM
CRL 01 SS's Avatar
I bought a brand new GM-OEM waterpump from a GM parts dealer off of E-Bay a few months back. It came with the good AC Delco gaskets, a warranty, and I received it just a few days after winning the auction. PM me if you want a link to one of their auctions.
Old 09-26-2006, 03:37 PM
KHShapiro's Avatar
Evans is hands down the best.
Old 09-26-2006, 04:05 PM
98camaroLS1M6's Avatar
pepboys, brand new, 2years, no problems. Works well.
Old 09-26-2006, 04:14 PM
Tech Resident
well, according to the sticky in the general information section, the GM part number for the water pump is as follows:
LS1/LS6 water pump (now same as LS2) (98-02) (AC-D #251-690) = 89017593 (f. 12458934)
if you put "89017593" in on gmpartsdirect, you get a "waterpump pump kit" for $163. Napa sells theirs for $160, so that's no big difference in my book.
Old 09-26-2006, 04:25 PM
KHShapiro's Avatar
https://ls1tech.com/forums/showthrea...ans+water+pump
Old 09-26-2006, 05:33 PM
Tech Resident
no way man, $475 for a water pump? no way, not in a million years. too much money for me
Old 09-26-2006, 06:17 PM
KHShapiro's Avatar
you stated money wasnt an issue
i use one but then again i need it.
Old 09-26-2006, 06:34 PM
Tech Resident
money wasn't an issue regarding the choices on the poll as they were roughly the same price. they're all around $160. if you're bringing in a ~500 dollar pump...can't handle that right now
Old 09-26-2006, 06:35 PM
KHShapiro's Avatar
go with the ls2 style pump and pull the pully out a bit its cheaper
Old 09-26-2006, 06:36 PM
joecar's Avatar
This brand: http://www.airtexproducts.com/
Old 09-26-2006, 07:46 PM
1BadBlueSS's Avatar
I work at napa so i might be partical, but the as long as you get a NEW napa pump i can bet you it will be an original GM unit. Make sure the pump your getting is a DPW unit from napa. The only other pump i would get after market would be a NEW airtex unit. The only reason i would stay away from an autozone pump is because they take any pump from any company and throw it in there box, so you can never tell what brand pump your gonna get.
Old 09-27-2006, 07:47 AM
jam01's Avatar
i would stick with gm, but if you do go aftermarket make sure you get a new pump not rebuilt.
Old 09-27-2006, 01:47 PM
Mr Incredible's Avatar
I dunno...I haven't gone through enough yet to know which is the best. I hope I never do!
But, I got my waterpump at Advanced Auto a couple of weeks ago and it still works...
Old 09-27-2006, 02:03 PM
98redM6's Avatar
There's also another part # 88894345 on gmpartsdirect.com.
It is like $25 cheaper than the other one. I don't see much of a difference, but maybe it is just the pump and not the entire kit.
Old 09-27-2006, 09:23 PM
Tech Resident
the part i put in, i think it says it's the LS2 style pump. i guess that means it's a slight upgrade? i dunno, i just used the number from the general maintenance and repair section on here. for an extra $25, if the LS2 style is better, i'll go for it (assuming it's a direct swap, no modifications needed). it's spending an extra $200 that i'm against
Old 09-27-2006, 10:13 PM
KHShapiro's Avatar
i think the ls2 pump spins slightly slower making less cavitation , depending on who the ls2 is a better pump.it will fit an ls1 you just have to pull the pulley out a bit.
like i stated earlier it is cheaper.. GL on you choice
Old 09-27-2006, 10:39 PM
ls1_doc's Avatar
I like anything airtex uses. I am not a big fan of napa waterpumps and would never do an autozone type store pump. The gm one would also be a good bet.
Quick Reply: Best Waterpump: GM vs. Napa vs. Autozone vs. Advance vs. Other
