which would you use?
Old Mar 8, 2002 | 08:24 AM
NVE THIS's Avatar
Default which would you use?
Would you use the Fast Toys Ram Aim System, or the Brian Green Ram Air Mod? Performance Gains?
If I use the FTRA, then I have to seal the nostrils, right? If I use the BG Mod, then you can't cut the bottom out, right? So which do you thik will give better performance gains at the track? Thanks.
Old Mar 8, 2002 | 09:19 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: which would you use?
You have a WS6. I'd definitely do the BG setup over the FTRA. I'd only consider the FTRA if I owned a Camaro, since we can make the nostrils on our Firebirds functional.
Tony
Old Mar 9, 2002 | 11:29 PM
Amarillo3's Avatar
FTRA does have some drawbacks
1)blocks off half your radiator - car runs hotter.
2) auto's have problems mounting tranny cooler.
I have a Z so honestly I've never looked at that other mod butjust pointing out.
Old Mar 14, 2002 | 05:24 PM
WILWAXU's Avatar
Like I said over on EFA.. Do both <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
