HELP! Big time.
Old Mar 16, 2002 | 05:51 PM
SSValet's Avatar
Default HELP! Big time.
I am lengthening my crankshaft positioning sensor and I need to know the color and position of each wire out of the plug.
This has already burned once and I had a generic Delco plug wired to the blue, yellow, and green wires.
Unfortunately in my haste I cut before marking the wires, I know stupid <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> , but I just need to know the colors of the wires in sequence with the clip side up.
Middle is yellow, I believe, please anyone with a rolling chassis or that has their starter out right now.
I'm frozen until someone who knows or can check for me replies.
Thanks.
Old Mar 16, 2002 | 06:36 PM
WILWAXU's Avatar
Default Re: HELP! Big time.
What is it burning on?
Old Mar 16, 2002 | 06:56 PM
SSValet's Avatar
3 times the headers have cooked it.
It's the same thing that PSJ went thru.
I am routing mine the same way his is.
Old Mar 16, 2002 | 07:14 PM
wizkid's Avatar
Install Director
I just put MAC headers on my car and I noticed that the positive starter wire, O2 wires, and the crankshaft position sensor wires are very close to one of my tubes on the passenger side. I taped the starter wire up with special heat reflective tape and a zip tied it away as far as I could from the header tube trying to get it back far enough. I am not sure I did.
How much space was between the black convoluted tubing and tube? Did you try heat tape? I think you did but maybe I am getting you confused with someone else. I find it hard to believe very few people have problems with this.
Here is the schematic out of my 1999 Service manual.
Click here for picture
Eric
<small>[ March 16, 2002, 07:18 PM: Message edited by: wizkid ]</small>
Old Mar 16, 2002 | 08:29 PM
SSValet's Avatar
Wizkid you're awesome.
In a nutshell, my whole harness was not installed right when I had my H/C put in. Consequently it burnt the CPS wires completely.
Since then it has been slightly cooked twice.
The last time I used not only heat blanket wrap but reflecta shield tape over that. Still cooked.
So now I am routing down the fender well towards the a/c line and back down along the motor mount, way far away from those tubes.
Your pic was exactly what I needed.
Thanks so much!
Old Mar 16, 2002 | 09:41 PM
wizkid's Avatar
Install Director
Dave, you are welcome. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I know how it is when you "need" a reply quickly and are in the middle of an install. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Good luck on your re-route.
Can you clear up one thing for me, when you said
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">my whole harness was not installed right when I had my H/C put in. Consequently it burnt the CPS wires completely.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What do you mean not installed correctly? I am unsure how all that conglomaration of stuff could get moved so badly. How close is your starter wire (red one) to the header tube?
Thanks,
Eric Barger
www.installuniversity.com
Old Mar 16, 2002 | 10:15 PM
SSValet's Avatar
It was the three Cps wires that were burnt all the way thru.
When the motor went back in, the protective heat wrap that was on there got shifted around backwards so it wasn't protecting anything.
And unfortunately, thru oversight, the bare wires were just coming across the bottom of the header tube. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
So when that happened I wrapped the cps wires along with the other three sensor wires so that heat would not kill the wires.
Unfortunately the cps wires seemed to be the most sensitive to heat.
The worst part was that it would happen at any time once the motor was up to temperature...just idling at a light and the engine stops with a check gauges light on.
Hopefully this does it, third time should be the charm.
Big Thanks to you Eric, and PSJ for hooking me up with his friend Russ.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 16, 2002 | 10:19 PM
DriveATransAm's Avatar
i believe prostockjohn has done this. might want to contact him.
 Michael S. Palmer
