evans vs meziere
Old Apr 18, 2007 | 09:17 AM
SS101's Avatar
Default evans vs meziere
which pump is better???
evans says that their pump flows more coolant than stock and maintains an equal coolant flow to both banks...
meziere says that thier pump increases power and runs the motor cooler...
(do you really need a standard small block chevy t-stat w/ these pumps or does the LS1 stat work too???)
which would be better for a turbo+nitrous road race/daily driver w/ 5-15psi of boost, 100 shot of gas @ 10:1 compression on 346ci????
Old Apr 18, 2007 | 11:07 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I have no idea the differences between the two (I run a Meziere), so I won't comment on that.
As for needing a small block Chevy thermostat with the Meziere - you do. The thermostat goes in a different spot in the EWP. SBC Thermostats are much cheaper than the LS1 stats, which makes it nice. Swapping thermostats is also super easy (you don't even have to drain the entire radiator).
Old Apr 18, 2007 | 12:34 PM
Gregory's Avatar
I have a Meziere in a 402. You can omit the small block thermostat that comes with it and use the stock LS1 thermostat. It is your option as to which thermostat you use.
Old Apr 18, 2007 | 12:49 PM
Juiced's Avatar
if i were you i would save the money for the new motor your going to need after you blow it up.
