I Need Some Help Installing my SLP Headers
Do the search and read up, it is the best thing you can do. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Eric
www.installuniversity.com
<img src="http://communities.msn.com/_Secure/0NAB!GfUQBaWAQyusDSi8K4modB00VnMJitRBgWJGvqaaLFUMY xX2mk6s0770DVGHC!VkMuw0LW5fflyaQU1r9g/Pict00211.JPG" alt="" />
If you don't take car to protect these wires your life will suck until you fix the wires. The headers touch the orange wrap and if not done right will melt the wires and you car will not run. I made a heat shield to help cover it. But as you can tell my heads where off. You will have to lift your car as high as possible. The passenger side will go in pretty easy. the drivers side you will have to take the steering knuckle off and maybe lift the motor toward the passenger side. Take out your plugs before you start. Dont put the O2's in until the header are installed.
I saved loads of topic on this to my site...
Good Luck and be patient!!
Jeff
