Any Holley intake dyno?
Old Mar 20, 2002 | 04:37 PM
andy98Z's Avatar
Default Re: Any Holley intake dyno?
I ordered mine 2 months ago. I should get it in 2 weeks.
Old Mar 20, 2002 | 04:40 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Holley Intake = bolt on. And I haven't seen any dyno numbers on it yet either.
Moving to External Mods...
Old Mar 20, 2002 | 08:00 PM
Chris Spiess's Avatar
I saw somewhere - this is from a vauge memory so take it with a grain of salt - can't remember where, but they got 9hp over an LS1 intake and 3(?) over an LS6. Not worth the extra $$$ or weight IMO. I would consider this only if going to heads and having it ported to match and ported for a larger throttle body.
Old Mar 20, 2002 | 08:23 PM
BADZ's Avatar
Moderator
Testing on a John Lingenfelfter 386 ci 8.78:1 compression LS1 reveals that the Weiand 300-111 adds 10 peak horsepower and 9 lb-ft of torque out-of-the-box over a factory LS6 intake! (Additional gains can be realized due to the ability to port the manifold)
Old Mar 21, 2002 | 12:16 AM
RUF SS's Avatar
Default Any Holley intake dyno?
I am thinking of getting one, but what to see how much gain from a stock intake!
Any dyno #s yet?
Old Mar 24, 2002 | 10:59 PM
VINCE's Avatar
Shorty Director
What happened to all those people that were having theirs installed last week..?
Old Mar 25, 2002 | 12:39 AM
Raughammer's Avatar
D(irecto)r Pepper
MTI had like 5 of them last week.
I am interestedin more info on this mod... anyone?
Old Mar 25, 2002 | 01:35 AM
VINCE's Avatar
Shorty Director
5 of them.. I cant wait to hear from them..
 Michael S. Palmer
Old Mar 25, 2002 | 02:24 PM
O2BQIK's Avatar
I thought it was the same dimensions as the LS6 intake? If that's true, then I wouldn't think you'd see any gain over a regular LS6 intake, perhaps even a loss since any metal will retain more heat than composites. That is of course until someone ports it...THEN we'll see what the big advantage is (or isn't).
Old Mar 27, 2002 | 10:27 AM
Duntov097's Avatar
TTT I can't believe nobody has dynoed this yet.
Old Mar 27, 2002 | 11:07 AM
NataSS Inc's Avatar
I am waiting to see the dyno's on this also. I am going to an MTI stage 2 heads and a C1 cam with FLP's. I want to get the holley intake also for the ability to port match. I think thats the only place anyone will see any real big advantages with this mod. As far as the heat soak issue. If its that big of a deal, bring ice bags to the track.
Old Mar 27, 2002 | 03:52 PM
BADZ's Avatar
Moderator
I did get one and it's getting major port work done now, cutting the bottom out and re-tapping the holes and adding a new bottom plate for more extensive porting and having more access in the runner sections...
Will be done soon and sitting on top of the new set up... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Raughammer:
<strong>MTI had like 5 of them last week.
I am interestedin more info on this mod... anyone?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Mar 30, 2002 | 10:44 PM
QuickSilverTA's Avatar
I've got one on order and want some more info. TTT
Old Mar 31, 2002 | 09:27 AM
Elite_Hot_Rod's Avatar
Well,
We installed mine yesterday after returning from porting. Don't have any dyno numbers yet because it has an air leak. First we thought it was the screws on the bottom plate causing it not to seat properly so we ground the heads of the screws down some, still leaked. You can see indentations in the gaskets between the runners,which were caused by the washers on the head bolts, so we took them out and ground the washer down alittle until the washers were just past flush with the mating flange on the head, still leaked air. First thing Monday morning we are going to check the mating surfaces for flatness and then call Holley. We did do a base line dyno with the new heads/cam/tb and stock LS1 intake to compare with the Holley manifold when we figure it out, stay tuned should only be another day or so.
Old Apr 1, 2002 | 09:44 PM
Duntov097's Avatar
TTT
Old Apr 3, 2002 | 12:13 AM
jmX's Avatar
jmX
Any update?
