HELP.......Installing new exhaust!!!!!!
Old Mar 21, 2002 | 02:14 PM
My99TA's Avatar
Default HELP.......Installing new exhaust!!!!!!
I just ordered my Corsa exhaust and Im going to try to install it myself. I noticed when I had the car jacked up to change my differential fluid that the stock exhaust may be removed if I lower a few parts (control rods? not sure what its called). Do any of you have any ideas to make the install/removal of old system go any easier???
I heard someone say buy some type of clamp to round out the exhaust? Why are they shipped deformed???/
Please HELP, Im **** about my work and want to do this right....................
Thank you kindly,
Old Mar 22, 2002 | 11:37 AM
ktm520's Avatar
Default Re: HELP.......Installing new exhaust!!!!!!
from what i know, you remove the panhard bar and the lower shock bolts, but make sure the rearend is supported when you remove the shock bolts. then, lower the rearend with a jack, until the exhaust will pull out from the back.
