maft and 100 octane?
Old Mar 23, 2002 | 05:12 AM
hondakiller's Avatar
Default maft and 100 octane?
my maft will be here soon as well as my laptop but i dont have the autotap cable but the laptop has autotap installed already. since theres no cable i wont be able to atap it and find out for sure so i was wondering if i used 100 octane gas and leaned it out all the way with the maft would i get knock retard more power or what? im lucky enough to live by one of the sunoco stations that sells 100 octane at the pump.
<small>[ March 23, 2002, 05:13 AM: Message edited by: hondakiller ]</small>
Old Mar 23, 2002 | 07:22 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Default Re: maft and 100 octane?
You SHOULD NOT touch the MAFT until you have ATap!!! The only other way you should tune the car is with a wideband O2 sensor on a dynojet. If you lean the car all the way out, you're going to be running WAY too lean. You can't just add some octane and the pull a ton of fuel out of the car without seeing how it affects the engine! Your changes with the MAFT should be in small increments.
__________________
