walbro 340 pump info
Old Mar 25, 2002 | 09:27 PM
rich's Avatar
Default walbro 340 pump info
I just purchased a pump and I am wondering if anybody has any helpful info on the install or tech tips. It is used and I have no directions. I was also wondering if I need a fuel pressure regulator. I am running a stock motor with a 2 stage nx kit, only spraying 175 to 200 hp. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Mar 26, 2002 | 04:30 PM
MIGHTYMOUSE's Avatar
Default Re: walbro 340 pump info
an adjustable regulator would certainly be a good idea, but if your stock one is working correctly it should be ok.
i have that pump in my car, and have detailed the procedure more than a few times on here/ls1.com so do a search for it, good luck.
Old Apr 1, 2002 | 10:44 PM
rich's Avatar
No luck on the search. came up empty. If anyone has done the install please post it or e mail me I am going to install it this weekend
Old Apr 2, 2002 | 12:48 AM
2000 Camaro SS's Avatar
Rich did you ever find out the answer? I tried to search but they shut that off. If you know can you please post what you found out.
