Fuel Rail Mod - Surge Regulator
Old Mar 27, 2002 | 10:14 AM
DaveSchott's Avatar
Default Fuel Rail Mod - Surge Regulator
Anyone modded the stock fuel rail? I took apart the surge regulator and was going to modify as others have done. Is this really a restriction on a boosted car? Thinking of gutting it completely.
Old Mar 27, 2002 | 06:08 PM
WILWAXU's Avatar
Default Re: Fuel Rail Mod - Surge Regulator
This would be a good question for Harlan over in the Forced induction area.. TTT.
Old Mar 27, 2002 | 07:51 PM
y2khawk's Avatar
Dave
Gut that puppy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Since you've already taken it apart, you can see the size of the inlet to the damper. Pretty small.
With the regulator in the same position as the damper, i run the return out the back side. Same size hole, it's a restriction for return when i run higher voltage to the pump. I get pressure creap at high voltage/cold starts when the alternator is really juicing the pump.
It a restriction you can live without.
Old Apr 16, 2002 | 07:48 PM
2001CamaroGuy's Avatar
I have been looking all over the place on my 2001 z28 and can't find the fuel pressure regulator. Is this is? What are you talking about "modding" this? Any pics?
thanks
Chris <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old Apr 17, 2002 | 02:29 PM
MIGHTYMOUSE's Avatar
the fuel pressure regulator is at the end of the return line which terminates inside of the gas tank. look there..
the pulse damper is in between the 2 fuel rails, basically just something gm came up with to put in place of the 97 vett's regulator which was located there instead of making a new set of rails.
