Help with stupid fuel pump
Old Mar 29, 2002 | 06:58 PM
70 LS1's Avatar
Conversion master
Default Help with stupid fuel pump
Ok, I am feeling really stupid now. I just picked up a Walbro 392 inline pump. Which end is the inlet and which is the outlet?
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Thanks
Old Mar 30, 2002 | 12:00 AM
WILWAXU's Avatar
Default Re: Help with stupid fuel pump
It's been a few years.. but they use to be marked.. small arrow on the npt fitting and aeromotive had it on the body of the pump.
<small>[ March 30, 2002, 12:00 AM: Message edited by: WILWAXU ]</small>
Old Mar 30, 2002 | 12:08 AM
70 LS1's Avatar
Conversion master
Thanks, but no markings.
Old Mar 31, 2002 | 05:54 PM
Mach Go's Avatar
Jeff....this may not be accurate, but shouldn't the inlet of the pump have some sort of screen to keep debris out of it??? If one end has a screen and the other doesn't then that may be your answer. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
jason
Old Mar 31, 2002 | 06:08 PM
70 LS1's Avatar
Conversion master
No screen here, this is an inline pump if that helps.
Old Mar 31, 2002 | 06:11 PM
y2khawk's Avatar
Outlet should be the end with the electrical connections.
Old Mar 31, 2002 | 06:15 PM
Mach Go's Avatar
Jeff....I just had a revelation....put some fuel line hose on both ends....submerge both lines in some gas then apply 12 volts...you will then be able to tell which is inlet and outlet <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Why didn't I think of that before??!! Duh
Jason
