Leak
Old Apr 23, 2007 | 02:19 PM
blackbirdls1's Avatar
Default Leak
I might have a possible small lead on my passenger side header collector or gasket, any way to verify for sure? When I slightly accelerate, very slightly I hear this noise, kind of hard to describe. Unless its a loose plug/wire.
Old Apr 23, 2007 | 02:24 PM
black01_WS6's Avatar
if it was a loose plug or wire you would probably be misfiring, causing your car to run horrible.
pop the hood and listen to see what side it is coming from, then get under the car and feel for air leaks around the connections while the car is running.
You could always seafoam your car and look for leaks that way as it would be white smoke coming out.
