MAC VS SLP
This is off the top of my head, so if Im wrong sorry.
-Doug
I personnaly like the SLP headers.. but if cost is a concern.. then they are far from the top of the list.
Mike
-Doug
A full length "tuned" header will always make more power.But there are advantages to a mid-length,such as improved ground clearance.Full length headers can be a real pain in *** to live with on a daily-driver.I can now change a flange gasket 20 minuites!
<strong>I'll be the first to say they'd (SLP)probably be a MAJOR pain in the @ss to install. Ive never done it but I can imagine how bad it would be. The macs on the other hand look like they'd fit right in.
-Doug</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">well doug, i have installed a set and i will tell u that the installation was simple. it was my first header install ever and i did it in the drive way, i can honestly say that flp's, macs, etc. could not have gone in any easier than the slp's, all the hype around the slp fitment issues is just that, hype. dont knock it till u have done it,......
jasson
Paul
<strong>I cant remember where it was, but I saw a post from either Tom or Larry from Speed, Inc. saying on mild cars the difference between macs and slp's is normaly 8-10rwhp. The difference was larger on head/cam cars.
-Doug</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Saw a dyno test of MAC's (flowmaster Y, cleaned up primaries, no cat's) on a bolt on car that made about 10 rwhp more on the top end than the SLP's did.
The SLP's made about 10rwtq more than the MAC's down low and in the mid-range.
The car's owner stated the car gained 1 or 2/10's at the track with the SLP's over the MAC's. The car was a convertable so the extra torque probably really helped.
Mid-lenght design MAC header with the 1 3/4 inch design primary of the MAC will make as good top end power as the SLP or probably better with a good collector and the normal MAC mod's.
Long Tube designs like the SLP with the 1 3/4 inch design primary will make better torque than the Mid-lenght and similar to slightly lower top rpm hp.
With that said, if money isn't an issue, I'd probably take the SLP's over the MAC's as the SLP's sound good and make more extra power where a "daily driver" bolt on car uses it.
If the car is mainly for the track and/or money is an issue, the MAC's can do just about as good for less cash. With a heads and cam set up that favors peak numbers, I'd take the MAC's.
Both product's have their niche and both can be the best depending on the intended application.
<small>[ April 22, 2002, 08:59 PM: Message edited by: 99 Black Bird T/A ]</small>
