WEIGHT REDUCTION
Old Apr 22, 2002 | 11:56 AM
BLK00TA's Avatar
Default WEIGHT REDUCTION
I HAVEA 2000 WS6 TA. I WANT TO REDUCE THE WEIGHT. WHAT CAN I REMOVE TO LOOSE SOME WEIGHT ON THE CAR. I DONT WANT TO DO ANYTHING CRAZY LIKE REMOVING THE SEATS OR ANYTHING LIKE THAT.
Old Apr 22, 2002 | 02:18 PM
PaiN's Avatar
Default Re: WEIGHT REDUCTION
check the drag racing section there is a huge weight reduction list there.
good luck
Old Apr 23, 2002 | 12:15 AM
Terry Burger's Avatar
First go to uhaul and rent a cherry picker. You need one that can hold at least 2 tons, but it has to have short enough legs that it can slip under the front of your car. If you're lowered you'll also need wheel ramps to jack the front of the car up a few inches.
Go to home base and get some chains and straps that will allow you to attach the cherry picker to your radiator cap. Jack the cap up around 36 inches, and roll a Honda civic underneath. Carefully lower the cap. Instant 750# weight loss. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
