walbro 255 inline fuel pump leaking
Old May 1, 2002 | 11:29 AM
Ls1 382ci SS's Avatar
Default walbro 255 inline fuel pump leaking
for some reason the other day in the drive way while the car was on something told me "look under the car" so I did and I saw a liquid leaking. i smelled the small puddle under the car and it was gas. I looked to see where it was leaking from and it was coming from the bottom prtion of the inline fuel pump. I couldn't go directly under it cause it was hot so I waited and went under this morning after I started it for a minute and let the pressure build up. I went checked the lines and everything seems ok, but the only part that is soaked is the rubber surrounding the bottom of the pump. anybody else have this problem? i figure if it's leaking something must be loose but i checked and I couldn't find anything. could it be a small crack? <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old May 2, 2002 | 08:01 AM
WILWAXU's Avatar
Default Re: walbro 255 inline fuel pump leaking
ttt
Old May 2, 2002 | 03:15 PM
nobody ever have this problem? <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old May 2, 2002 | 04:41 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
ZBass28@aol.com has had this problem before.
Old May 2, 2002 | 06:36 PM
ok, thanks Speed Racer.
Sincerely Racer X <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" /> <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
